Results 1 to 6 of 6
Thread: non start startor motor clicking when trying to start
    Feb 2008
    Tamworth
    corsa 2 litre 8v
    on a 2 litre corsa (c20ne engine). swapped startor motors over...battery has been on charge for 45 minutes. Cleaned the chassis earth to gear box earth. put the negative clamp from battery charger to gear box to by pass chassis still no look. any more ideas?
  2. #2
    MIGClub Discounts TINTIN's Avatar
    Dec 2001
    Southampton/Reading
    The Pheonix
    Re: non start startor motor clicking when trying to start
    Are you sure that the starter you swapped for is any good?
    Can you offer discounts to MIG? If so please email discounts@migweb.co.uk with details
    Advertising opportunities at advertising@migweb.co.uk.
  3. #3
    MIGClub Member corsadonk's Avatar
    Jan 2009
    Wiltshire
    R1'd xe corsavan.
    I'd check you battery is holding a charge, sounds flat to me.
  4. #4
    MIGWeb User gjay's Avatar
    Nov 2005
    boston lincs
    coscast astra gte
    as above, and also try jump leads with a running vehicle hooked up (have a fresh air break) then try, if you have a low amp chager it can take all night/never to charge a flat/knackered battery
    show no fear...................grab another gear!!!!!!!!!!!!!!!!!!!!
  5. #5
    Feb 2008
    weston-super-mare
    mini c20xe itbs mbe
    done this a few times and have had the same thing happen check the main live to the starter in tight as a slightly lose one wont work just check its niped up with a spanner .it happens because when you put in the starter the twisting makes it loosen off .
    James
  6. #6
    Feb 2008
    Tamworth
    corsa 2 litre 8v
    Yes the startor i put on is a good spare one. Basically today i cleaned up all the earths cleaned the wiring going onto the startor motor, still did the same. Swapped over batterys with my mums. still did the same so put mine on i put the battery charger on it whilst having a jump lead going from neg to battery to gear box to act as an earth to rule out the gear box to chassis earth still clicked when trying to start. Left the jump lead still on turned the ignition on and got a wire and bridged the back of the starter the engine fired up straight away. I then removed the jump lead to neg on battery still started up, removed the wire on back of the stater motor. wiggled the wiring around still started up. I had a look at the igniton switch ont he barrel but didnt know how to get it off so left it incase i broke it. Anyone got any ideas on what it could be thanks
