management light
hey all , just put a afr gauge in . plumbed it into number 25 of the ecu which is the lambda signal, but not sure if this is correct. its the x20xev ecu simtec 56.0/56.1. It knocks the mangement light on . Any thoughts
Re: management light
autodata does say pin25 for simtec 56.0/56.1 what year/model is the car?
is it definatly 56.0/56.1 and not 56.5?
