If doing a corsa b xe/let conversion.
Which ecu would you use and which keys?
Can the immobiliser still be active or does that have to be binned?
cheers
cheers
0-60 in........about a minute!
You need an immobilised ECu for a start with the Chip and reader from the ignition barrel.
Easy enough to wire up, especially if your corsa had one already.
so i use the xe/let ecu and which keys and ignition? do many people use an immobiliser?
you need the chip and reader for the immobilsed ECU.
It's easy enough to fit an aftermarket tranponder immbobiliser so using an earlier ECU isn't a problem.
