Hi ive just bought an x plate 1.8 16v mk4 astra as an mot failure,needed a tyre,cv gaitor(both done) and emissions looking at as it failed on co test at idle.Plugged into diagnostic and come up with the above codes,1 is the maf and the other is air intake temperature.Tried re-setting codes after i fitted another maf but still coming up with these codes.Only fault with the car driving is that it goes to cut out and splutter as you pull off but goes ok then.
Any ideas?Could it be a faulty ecu?
