Results 1 to 6 of 6
Thread: Corsa B with Cavelier Hub
    Jun 2004
    Sheffield
    Mk5 Golf GT
    Does anybody know what bearing to use for putting a Cav hub into a Corsa carrier?
    Don't want to machine the hub down as I feel this could cause weakness.
    A little bird tells me maybe there is a VW bearing that could do the job? Anybody any input on this?
    13.5@ 108mph.... No LSD, No NOS And Full Roadtrim... Datron timed 0-60: 5.38. Now got an LSD, just got to fit it!
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    Re: Corsa B with Cavelier Hub
    usually you machine the hub to take the corsa bearing
    www.wix.com/vxlgsi/zxr-750-r
    Jun 2004
    Sheffield
    Mk5 Golf GT
    Yeah only want to go that route as last option. It's how it is now.
    Cheers anyway!
    Macclesfield
    www.Retrobike.c
    IIRC you have to machine hub and flange still using the different bearing but its far stronger than machining just the flange.
    Back in the scene
    Jun 2004
    Sheffield
    Mk5 Golf GT
    Any idea what bearing to use Rick? Getting any machining done is not a problem.
    Jun 2004
    Sheffield
    Mk5 Golf GT
    and wot part of the hub needs machining ?
