Results 1 to 17 of 17
Thread: Astra mk4 gsi Alarm and starting problems help?
    MIGClub Member fennyLET's Avatar
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    The Alarm siran on my gsi doesnt work. I take it that it is another horn like most other vauxhalls.
    Were is the location of it so i can change it to see if it is that?
    Also when i brought the car. On start up you would turn the key and it would fire straight up, rev itself abit and and settle fine. Sometimes now it crancks over and struggles to start and the revs sit very low. So its trying to stay running. So you have to give it abit of a rev then its fine.
    Hard to explain really but what could cause this?
    Many thanks
    Aug 2007
    United Kingdom
    Shogun/MK1 Escort
    Re: Astra mk4 gsi Alarm and starting problems help?
    There is the alarm under the scuttle panel and the power sounder under the passenger fronrt arch liner, what engine is it?
    Jack said,
    Surely you are only pulling it one way though? ie. you are pulling it along its length.
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    Its the Z20LET.
    So the power sounder is the same haorn as the horn? My horn works fine.
    Aug 2007
    United Kingdom
    Shogun/MK1 Escort
    Quote Originally Posted by fennyLET View Post
    Its the Z20LET.
    No, your "peep peep" horn will be under the bumper NSF. your power sounder is under the OSF arch liner.
    Jack said,
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    Quote Originally Posted by keithcdb View Post
    O rite cool. Ill have a look for it. Cheers
    Moderator Nobbie's Avatar
    Hemel Hempstead
    with blue lights
    The powersounders always seem to die.
    As for starting it could be something as simple as a tired battery, or maybe try a new cts if its only when cold. If it's lumpy when hot maybe afm, if it's all the time the stat could be stuck open, and is annoying the ecu, so check your temp gauge.
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    Are the "powersounders" a horn? If not is there another vaux with the same thing on it? IE Vectra?
    MIGWeb Moderator
    Midlands
    Nowt
    Its like a unit on its own pal
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    Ok ill have a look and see what i can find..... Cheers
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    Ive just looked at a 1.7 Derv ive got out the back. Is this unit like a ECU? Ive found two. One up in the corner near the top of the wing/door and one near the front of the bumper. Both on N/S.
    O and my horn on my car is O/S just behind the bumper.
    Anyone got a pic of what im looking for?
    MIGWeb Moderator
    Midlands
    Nowt
    Not like an ECU no
    Its behind the passenget side front wing arch liner
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    I hant got a CTS in the yard with a white plug, only blue ones
    Ok cool it looks like a siren. Should be able to spot that
    So have i got to buy a new one of these or do other vauxhalls have the same thing?
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    Ive found my power sounder. Looks like the above.
    Ive found that when i disconect the battery then re conect it, it will then go off.
    Ive also tryed a Vectra one (Unsure if working) but nothing happend.
    My problem is that it doesnt go off when the alarm is going off.
    I undone the window and locked the car. Then set the alarm off. The indercators flash but no power sounder.
    Is my power sounder broken or is the problem elswere?
    Cheers
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    bttt
    Aug 2007
    United Kingdom
    Shogun/MK1 Escort
    It not ment to go off when the alarm go's off, its ment to go off if the battery is disconected during a robery attempt.
    Jack said,
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    isnt that abit silly? Whath appens if someone does take it.... they drive done the road with just the lights flashing?
    Aug 2007
    United Kingdom
    Shogun/MK1 Escort
    The other siren should be going off
    Jack said,
