Results 1 to 9 of 9
Thread: no brakes corsa
    Oct 2009
    birmingham
    no brakes corsa
    jsut put discs on corsa and i seem to bleed all the brakes up and they still dont work any ideas cheers
    Jun 2009
    Doncaster
    1.0 Corsa b
    Re: no brakes corsa
    not bein a daft question but did you put the brake fluid cap back on? school boy error that iv done once.
    0-60 in........about a minute!
    MIGWeb Moderator
    Midlands
    Nowt
    Re: no brakes corsa
    Why would the cap being off make a difference?
    Pedal going straight to floor?
    Not removed the calipers at all?
    No resistance at all?
    What year is the car? Standard factory brakes?
    Feb 2010
    Stranraer, Scotland
    Corsa B C20XE
    Re: no brakes corsa
    What method did you use to bleed them? You don't need to bleed them when changing discs or pads.
    "If in doubt, FLAT OUT!"
    Colin McRae 1968-2007
    PSN - steve-gers1989
    Feb 2007
    peterborough
    vectra x20xev turbo
    Re: no brakes corsa
    when you pushed the piston back to make them fit the new discs do you remove the fulid cap as if not you can blow the seals
    need more boost lol
    Oct 2009
    birmingham
    Re: no brakes corsa
    its a m red corsa be and no its has 256mm vented discs on the front and 256mm normal discs on the back
    i needed to bleed them up because of putting the new rear brakes on so started furthest away from the master cyclinder working my way round, cheers for the help
    Feb 2007
    peterborough
    vectra x20xev turbo
    Re: no brakes corsa
    are the calapers on the right side as a few people have done this and had the bleed nipple at the bottom
    need more boost lol
    Sep 2009
    slough
    corsa
    Re: no brakes corsa
    why do you have to have the cap on?
    Oct 2009
    birmingham
    Re: no brakes corsa
    yes calipers are on the rite way round
