I am in the middle of a conversion on a mates astra gsi and we want to take off the abs.
He currently has a 2 output master cylinder,
How is it best to plumb this in to all 4 wheels?
The idea we had was to put a t peice in each output and then run in FR RL / FL RR with a restrictor in the line to the rear, but the problem we are having is that we cant find a conntector that enables you to connect to the input side of the restrictor - as they use a much larger thread directly into the non abs master cylinder.
Is there a commonly available 4 output master cylinder that will take restrictors - that has the correct bolt pattern (ie bolts at 2.30 & 7.30)
Or any other ideas with aftermarket stuff
