how to wire up a second battery and split charge relay
Results 1 to 8 of 8
Thread: how to wire up a second battery and split charge relay
    Dec 2008
    Lincoln
    Disco 200TDI, CBR400RR
    right i'm starting my MK3 astravan project, and i'm ply-lining and then carpeting the back, the plan is to have 4 6x9s in the roof, powered from an amp, and some extra lighting in the back too, as its gonna be a bit of a camper so instead of flattening the normal battery, i'm gonna put a second leisure battery in the back to power the stereo, amp and interior lighting from. which will obviously need charging, so....
    my question: how do you wire up a split charge relay? what size cables will i need running to it? and is there anything special i need?
    ta
    [SIGNATURE] [/SIGNATURE]
    Apr 2004
    Woodford, Essex
    '95 MR2 GT
    Re: how to wire up a second battery and split charge relay
    Just take a look around for caravan split charge systems. There are plenty out there plus all the info you could want about fitting them
    Dec 2008
    Lincoln
    Thread Starter
    yeah i thought they were fairly common caravan things. one of the guys at work is big into caravans (built his own out of a sprinter, its lush inside), so i'll ask him. cheers for that =)
  5. Remove Advertisements
    Mar 2002
    suffolk
    Corsa T, Cally T, 16v GTE
    if you buy a split charge relay it will have wiring diagram with it.
    www.facebook.com/ttvracing
    https://www.facebook.com/zxrninjaowners
    ZXR750 M1/M2 www.wix.com/vxlgsi/zxr-750-r
  7. #5
    MIGWeb User J Sabo's Avatar
    Aug 2005
    Cambs, PE15
    Mk4 SRi-T + Van
    a split charge relay is JUST A relay - high amps though.
    2 large terminals connect both batteries
    1 terminal Earth, the other connect to the Blue/White wire from Alternator to battery dash light
  8. #6
    Aug 2005
    Cambs, PE15
    Mk4 SRi-T + Van
  9. #7
    Dec 2008
    Lincoln
    Thread Starter
    cheers for the link, reckon i'll get one of them! thanks
  10. #8
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Quote Originally Posted by J Sabo View Post
    No it isn't - also incorporates blocking diodes to prevent cross discharging.
