Z20LET boost/running issues
Results 1 to 11 of 11
Thread: Z20LET boost/running issues
    Scottish Regional Co-ordinator
    Sep 2004
    Fife
    Cav T, SRi, V70 TD & 850R
    Gents, would appreciate some input here. I've had a look through some historic posts about this and being fair, there seems to be a bit of conflicting information so I'm a bit unsure/fed up now!
    CAR
    2003 Astra GSi turbo with 70,000 miles - standard bar a remap, however we have checked the map and it bears no significance as the car has been doing this prior to it being mapped.
    SYMPTOMS
    Hestitant under boost and when maintaining contsant speed on the motorway. Can power through hestitancy although occasionally emission light will illuminate and restrict power. However when the light is on, the car drives alot smoother all be it with little or no boost.
    When the emission light is on, disconnecting the multiplug at the boost sensor has little or no effect on the car... whether this has any relevance, I don't know. Likewise, I can disconnect the ECU which clears the light and returns the car to full boost, all be it very hestitant and surges.
    Additionally, the car suffered coolant gauge issues. It'd regulary read cold or drop out for no reason. I changed the sensor and although the car now runs a constant temperature, it runs around 80deg despite having a 92deg thermostat. Could this perhaps be related to the common earth issue too?
    FAULT CODE
    Vauxhall dealer check and found P1106 stored relating to boost sensor or similar and immediately decided the boost sensor on top of the intercooler was defective.
    SO FAR
    I've declined the boost sensor at present, done some research and found the technical field remedy for the poor earth. On Saturday I removed the battery and tray and went searching for said earth connection (4 earths, crimped and onto block) however for the life of me cannot find said connections? Anybody have a picture/diagram to hand?
    The only earth I can see on the injector loom is the two wires bolted to the side of the inlet manifold. I traced these back and it appears one buggers off along by the injectors and the other is for the coil pack. There is another but its unclear where it goes although apprars to enter the loom and disappear down towards the battery.
    On advice from those in the know, it could be either a faulty boost sensor on top of the intercooler, a faulty boost control solenoid/amal valave, mass air flow meter or the wiring issues. My local dealer knows nothing about the latter.
    FINALLY
    The car is due back into Vauxhall on Wednesday to recheck what has been done, truth be told I think I'm wasting my time. It has been suggested I change the mass air flow meter and boost sensor to elimnate them, however unless somebody is local and willing to let me try theirs for a quick roadtest... that's not really viable.
    Anybody experienced this before, or willing/able to assist in excahnge for some beers and worldwide gratitude and fame. Perhaps.
    Cheers
    Cavalier Turbo Owners Club - As long as it runs I really dont care...
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    Re: Z20LET boost/running issues
    Cant find P1106 but ive got P0106 witch is Map Sensor. (air leak, Naf sensor or wireing)
    Sep 2004
    Fife
    I know the code relates to the map/boost sensor... but there's more to it than that, hence the earthing issues and more to the point, where is said earthing issue as nobody seems to have the answer!
    Pom
    Pom is offline
    Feb 2007
    West midlands
    Suspect Airflow meter is faulty, defo worth tyring
    Jun 2003
    haslington
    zafira gsi
    Had similar fault on my Zafira after searching a few web site i was told to change the sensor on top of the turbo and the 1 on the back of the block and touch wood for the last 3 years the problem has never come back
    PS3 Gamertag monkey__socks
    Xbox 360 Gamertag M0NKEY S0CKS
    Jan 2010
    did u find out problem my act is hesitating too low gears off boost and on boost replaced everything apart from intercooler sensor and ecu
    Sep 2004
    Fife
    Unfortunately not gents, the story continues here:
    Z20LET ongoing boost/hesitation/running issues - Astra Sport and Astra Owners Club - Mk1 | Mk2 | Mk3 | Mk4 | Mk5 | Mk6 | Astra Van | 888 | VXR - All Welcome
    Airflow meter has been replaced, front boost solenoid has been replaced and the rear has been bypassed.... still the same but click the link for the full story so far, it's compelling and suicidal reading!
    Open to suggestions chaps, sick to the back teeth of it now.
    May 2006
    carronshore , falkirk
    astra 2.2 supercharged
    mate had the same problem it turned out to be the coolant temp switch
    Jun 2000
    Hampshire, UK
    Vectra SRi
    I know this is C20 LET related but I had a similar issue with my Cav Turbo.
    In my case it was the gap in the spark plugs, being a little too big the spark would be blown out by the force of the boost.
    Adjusting the gap cured the problem, but like you I had the ECU light on with a fault code that was boost related.
    Tom
    Sep 2004
    Fife
    Quote Originally Posted by Tom Williams View Post
    Tom
    A good point well made sir, it's running NGK Iridiums but on the standard gap so it's possible this is too much. Although given it only stutters under light boost, I'd have expected the plug gap to become more significant at higher boost levels. Certainly willing to try anything at this stage, so will drop the gap a baw hair and see what happens. The C20LET is definately a more simple beast to work on!
    Quote Originally Posted by mac1976 View Post
    It's been renewed already with a new GM part mate, but cheers
    Aug 2004
    South Yorkshire
    Track GTE Champion
    Sorry to bump an old thread but my SRi turbo is doing the same thing...just wonder if you ever sorted it?
    It's standard apart from an unknown remap, allegedly done by Courtnay but as they only keep the customer name not the car reg they couldn't tell me if they'd ever worked on the car. Removed the chav valve, replaced the boost control solenoid. It's also got a VXR turbo fitted, bought new in Feb
