i bought 4pot brembos from evo8 and want to install them with 309.7mm willwood rotor discs, so have some questions to you.
in stock evo brembos works with 320mm discs (not rotor type), so i need smaller pads couse rotor discs have smaller working space and i use smaller diameter of rotors.
stock evo pads
i found this pads
aslo i don't understand some rotor specs
what is lug id? is it a smallest diam (smaller than bolt circle) of rotor?
so, if i'm right (309.7-215.9)/2=46.9mm of working width plus i need to leave some free space on both sides (inner and outer radius of pad).
waiting for any help/advice
thanks!
stock evo pads
(62- working size, not width of all pad)
i found this pads
i saw, then pads on pics are different, but that's only scheme. could they be changeble?
what is far side id? is it a smaller diameter of working space?
thanks!
