i assume you mean to lower it?
if so i'm guessing that its on leaf srpings,
if that is the case then its the same as on a vw caddy etc, where you unbolt the u bolts and put the axle on top of the springs rather than hung underneath and you end up lowering it the depth of the axle plus the thickness of the springs - typically 80mm ish
I've seen this done to an escort van and it was easy enough to do, I shouldnt imagine it will be that hard to do on the combo as long as it's leaf springs it has
