installing turbo timer on z20let?
Results 1 to 13 of 13
Thread: installing turbo timer on z20let?
    Apr 2009
    Ayrshire, Scotland
    Mk 4 Gsi Turbo
    need help tryin to install my turbo timer (hks kit + harness ) on to my vauxhall astra gsi mk4 03 plate
    its moistly the wires on the steering coloum i dont wont to cut & join to rong wires
    Astra GSi Turbo 03 Arden Blue - Vxr Turbo,FMIC,Coilovers Anthracite Snowflakes,Scorpion Exhaust,Dump Valve,Irmscher Grill,Samco Hoses,Turbo Timer,HID Lights
    Feb 2003
    weston
    calibra 16v
    Re: installing turbo timer on z20let?
    The wires at the ignition switch are
    Thick Black Battery +
    Thin red Key in switch
    Black red to starter
    Then you have two smaller Black wires one is ignition 12v while cranking and the other is ignition 12v but 0v while cranking.
    You will need to connect the output of the turbo timer to the black ignition wire that stays at 12v on cranking
    Apr 2009
    Ayrshire, Scotland
    Mk 4 Gsi Turbo
    Thread Starter
    theres three thick black wires that stays at 12v & a thick red & a red & black, thin red & thin green
  5. Remove Advertisements
    Mar 2002
    suffolk
    Corsa T, Cally T, 16v GTE
    you need a constant live, a switched live and an earth.. thats it.. i didnt bother with the hand break or foot break switch's
    www.facebook.com/ttvracing
    https://www.facebook.com/zxrninjaowners
    ZXR750 M1/M2 www.wix.com/vxlgsi/zxr-750-r
  7. #5
    Apr 2009
    Ayrshire, Scotland
    Mk 4 Gsi Turbo
    Thread Starter
    im tryin to fit this turbo timer at the moment, having problems tho!
    fitted everything, when i pulled the key out it stalled & then was tryin to start itself
  8. #6
    Apr 2009
    Ayrshire, Scotland
    Mk 4 Gsi Turbo
    Thread Starter
    rite im 100% needing some expert help here, its (HKS TYPE 0 KIT & HARNESS) Can some one please take the time an explain all from the start, witch wire goes to witch wire please & what i need to do etc! really want it fitted before my new vxr turbo goes in, was in about it got on well & then hut a bad patch could not stop the from tryin to start when the key was out & the turbo timer was countin down, so would be greafull if some 1 would take the time & have a look on the net at the hks for a gsi n tell mee exaclty witch wires to witch wires & anyfin elsee thanksss
  9. #7
    Awaiting Email Confirmation
    Jun 2002
    I don't understand the problem... If jack-off is correct, then you just need to match this to the HKS wiring, which is available all over the net. I installed one of these using a multimeter. You can check which wire is powered at various clicks of the key and figure it out from there? If you can't do this, an alarm installer would be your best bet.
  10. #8
    Oct 2008
    clackmannanshire
    Coupe linea rossa
    if you fancy a run mate if your really struggling i could give you a hadn i fitted the blitz one on my astra and al went well just need the minimun know how. sure the hks will be abt the same as the blitz harness.
  11. #9
    Mar 2007
    hertfordshire
    c20xe & let cav's
    i have mine on the clifford alarm.
    happy days
  12. #10
    Apr 2009
    Ayrshire, Scotland
    Mk 4 Gsi Turbo
    Thread Starter
    thanks for the road trip offer but tad far cost me 50pound on petrol & a custom installer place is goin to fit it 25 - 40 pound,
  13. #11
    Apr 2009
    Ayrshire, Scotland
    Mk 4 Gsi Turbo
    Thread Starter
    know installed!
  14. #12
    Feb 2006
    west yorkshire
    mk1 astra and corsa
    im glad i found this im fitting one to my mk4 convertible this weekend
  15. #13
    Apr 2009
    Ayrshire, Scotland
    Mk 4 Gsi Turbo
    Thread Starter
    bye the way watch what yer doing because the dude who fitted mines fits alot & says sumtimes it its not done 100% yer emobilser does not work when ye lock yer car or yer central lockin!
