Advertise Here - Click for More Info
Old 04-07-2009, 23:10   #1
flez
Drives: Corsa LET
Fitting Top Nut On Spax
Hi all
Just fitting my Spax RSX Coilover kit to my corsa b, problem is i cant seem to get the top nut done up, when i use the existing top nut of the old setup all it does when i try and do the nut up is get itself on by a thread but as i try to do it up more it just turns the suspension shaft that it screws onto, how do i stop this and succesfully do the nut up
Thanks all
flez is offline   Reply With Quote
Old 05-07-2009, 02:33   #2
doge5644
Drives: Without Due Care
Re: Fitting Top Nut On Spax
any kind of impact gun will do it from air to an 24v jobbie
doge5644 is offline   Reply With Quote
Old 05-07-2009, 07:47   #3
Gordo
Drives: Chevette XE, Calibra
There should be a flattened of section at the top of the threaded portion, use a small spanner or shifting spanner to hold the shaft while tightening up the nut - there should be an illustration in the box to show how far/tight the nut should be.
Gordo is offline   Reply With Quote
Old 06-07-2009, 12:03   #4
BigDave1979
Drives: Nova 1.4 16v/BMW 330
I had the same problem, even with an impact gun - just kept spinning the shaft and wouldn't tighten down properly so I bought a deep socket nice and cheap and cut the side out of it so I could get a spanner on the top of the shaft and a torque wrench on the nut.
Edit: You can also buy sockets made exactly for that purpose but they were expensive compared to my nasty bodge!
BigDave1979 is offline   Reply With Quote
Old 06-07-2009, 12:16   #5
flez
Drives: Corsa LET
Thanks for all the feedback guys, found out i was being a dick and using a bolt with the wrong thread, the spax shafts are a fine thread where as i was trying to use a big thread nut, nut went straight on after that, all sorted now, thanks again
Old 06-07-2009, 19:28   #6
hay_lewis_68
hay_lewis_68's Avatar
Drives: carless =( CBR400
lol i did that with mine. tried using the original nut on new damper
hay_lewis_68 is offline   Reply With Quote
Old 07-07-2009, 10:01   #7
aussie astraGTE
Drives: MK2 ASTRA GTE 16V
i was about to say the nuts are different thread ,always wind the nuts on before you assemble to make sure they fit as i have bought new strut inserts & they put the wrong nuts in the box & i had loads of fun till i realised " i always check now ,
aussie astraGTE is offline   Reply With Quote
©MIGWeb 1997-2009 - MIGWeb Home - Archive - Privacy Statement - Top
Powered by: vBulletin. Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0
