been reading up on this and just wonderd if the astra gte digi dash can b fitted to a corsa that has an electronic speedo with out any problems
cheers
cheers
so any 1 know how u fit in to one of these dashes coz from what av read all the wires r the same and just join up to each other and all u need is the transponder ?? well ma corsa already uses an electronic transponder so is it just a case of pluging it in ???
Yes mate my corsa had a std transponder and my digi dash worked off that fine think i just had to flick the (red) switch at the top of the clocks to suit them, You have to run a wire from each turn signal wire to each turn singal wire on the digi dash plugs, as the std clocks uses the same light for left & right, where as the digi clocks uses 2 one for left & one for right,
I have a full wireing guide if you need it ??
When not on axle stands, I'm on boost......
aye that would come in handy like mate cheers
If you have a speedo pulse wire (normally blue with a red trace) if the speedo is reading wrong due to the pulses being wrong have a word with Dom off here (www.picbits.com) as he does a circuit which allows you to change the signal to get the correct speed reading.
I have a couple of these (one for the nova and vectra) and they work great!
Cheers
Joff
I don't do standard!
(Nova Turbo rebuild now finished)
but even if a didnt bother with the turn signal lights will it just plug in usuing the original wireing ?
sneakycorsa, would it be possible if i could get a copy of tht wiring guide, ive jst started mine but dont really know how to do it.
cheers
any chance i could get a copy aswell please as i'm just starting to do the same thing also with an electric driven corsa.
ive just wired all mine up, its actually rather easy, bloody speedo stop working after 3 days!!!!!!!
