Results 1 to 14 of 14
Thread: suspension help
    Aug 2006
    top of scotland
    mk4 astra sri turbo
    suspension help
    i am trying to put new jamex shocks on struts but cant get the big nut over the top of the shock as it is to tite.does it need to be pressed on?
    Aug 2006
    top of scotland
    mk4 astra sri turbo
    Re: suspension help
    btt.
    Liverpool
    people up walls
    Re: suspension help
    Have you compressed the springs as far as you can?
    Dec 2003
    N.Ireland
    3.0 Cav
    Re: suspension help
    okay.. the nuts not moving at all, or its spinning ??
    Infact, just read your post again and am confused.. have you the new shocks fitted?? and cant get the nut back on?
    Aug 2006
    top of scotland
    mk4 astra sri turbo
    Re: suspension help
    I have added a picture below of the Shock and the arrow on the picture is where the Big Nut will not go over.. The big nut being the one on the left of the picture..
    Aug 2006
    top of scotland
    mk4 astra sri turbo
    Re: suspension help
    is it possible to take the silver ring (where arrow is) off completly or maybe just file the amount off, needed to get the nut to fit over it..?
    MIGClub Member patrikbrunt's Avatar
    Oct 2005
    Somerset
    '02 Astra Coupe Turbo
    Re: suspension help
    bumping an old(ish) thread here, but did you ever resolve the issue? Ive gone to fit my jamex inserts this evening and found the same problem.. thinking i might have to turn a bit of meat out of the nut?
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    Re: suspension help
    Send them back and get some ones that actually fit Turning out the nut will weaken it and it's the only thing keeping the strut from popping itself open.
    Oct 2005
    Somerset
    Re: suspension help
    hmm I did worry about that... but these are the right inserts so they must be able to fit somehow?
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    Re: suspension help
    Phone Jamex and ask them? Does look to me though that they have just put a kit together and not actually tested it.
    Aug 2006
    top of scotland
    mk4 astra sri turbo
    Re: suspension help
    at the top of the shock were the arrow is i took the spacer ring off and it fitted fine then.as far as i no it is just a spacer ring.it does not hold the shock togethor.it comes off with a tap with a hammer.
    Jul 2002
    Leamington Spa
    Satsuma Castanet XR4Turbo
    Re: suspension help
    Ah.
    Oct 2005
    Somerset
    Re: suspension help
    I said that to my mate when we tried fitting them and he was like 'Noooo if you take that off all the oil will come out of the shock!' haha numpty
    Jul 2002
    Leamington Spa
    Re: suspension help
    Think it's held on with more than a sleeve!!
