99 astra heating system diagram help needed.
Closed Thread
Results 1 to 24 of 24
Thread: 99 astra heating system diagram help needed.
    Dec 2008
    Question 99 astra heating system diagram help needed.
    any 1 got 99 year astra heating diagram ? my heating isnt blowing hot air out and its making a clicking noise which is coming from a boxing which is at the left hand side of the clutch peddle? can any 1 help me with this problem at all? its not the heater matrix its doesnt need flushing either that as all been checked.
    MIGWeb Moderator
    Midlands
    Nowt
    Re: 99 astra heating system diagram help needed.
    Who checked the matrix?
    The box you refer to is the heater box that contains the matrix inside.
    Dec 2008
    Hi a mechanic checked the matrix? The clicking noise is definately coming from that area? a friend mentioned it could be a relay ? . I could do with a diagram of how i can get to that area so i can have a look? if you can help me please do
    MIGWeb Moderator
    Midlands
    Nowt
    Haynes manual would be best, not really covered on here.
    Dec 2008
    where do i get my hands on 1 of them? thanks for ya help 2
    Jul 2002
    Leamington Spa
    Nissan Fairlady Z / JTin
    Your mechanic has not connected the rods that open and close the flaps inside the heater 'box'. Does the heater 'blow'?
    I have a picture of the heater box thingy somewhere, I'll dig it out.
    Dec 2008
    the heater blows cold when on hot and cold when on cold and the pipes in the engine get hot so there is hot air its just not getting through? help!
    MIGWeb Moderator
    Midlands
    Nowt
    Quote Originally Posted by kiekie View Post
    Halfords etc. Done much work on cars before?
    Dec 2008
    not done much but im hopeing that the diagram that the other migweb user STATION is trying to find will help me out cos my car is freezing!
    Jul 2002
    Leamington Spa
    It's not electrical, there is a rod connected to the switch. When you move the dial along, it pulls the rod and operates the flap.
    Dec 2008
    how do i solve this problem once and for all?
    MIGWeb Moderator
    Midlands
    Nowt
    Best have a look at the side of the heater system and see if something has fell off.
    Dec 2008
    what am i looking for when you say fell off? and what bout the clicking noise that its making?
    MIGWeb Moderator
    Midlands
    Nowt
    To be honest you really need to have a look, then tell us what you see.
    Its not really something I can explain over the internet or show you a photo of - sorry.
    Mar 2006
    Worcestershire
    The wife mad.
    Has your astra got air conditioning? If so there is a valve in the water circuit between the matrix and pipes these are common for packing up and are also a pig to change. They screw in from the engine bay side of the bulk head.
    Dec 2008
    so can you explain the clicking sound coming from the boxing on the left hand side of the clutch peddle?
    MIGWeb Moderator
    Midlands
    Nowt
    Quote Originally Posted by BROOMY View Post
    The heater matrix has been checked, so i'm presuming coolant is flowing to it.
    MIGWeb Moderator
    Midlands
    Nowt
    We are just going to go round in circles on this.
    If you really fancy a bash, your going to have to stick you head there and have a look what you can see.
    Have you got a Haynes manual? Maybe some photos in there.
    Dec 2008
    it gets worse ive just taken the glove box out and now for some very strange reason there is no hot or cold air coming out now at all but the clicking noise is still there?
    MIGWeb Moderator
    Midlands
    Nowt
    Best get a mechanic to check it out for you if your getting stuck
    Feb 2003
    weston
    calibra 16v
    There is a valve in the pipes going to the heater matrix to shut the flow of hot water off when you have the aircon set to cold When they fail sometimes they start to make a clicking noise. Try disconnecting the plug to see if the noise stops.
    Nov 2010
    Quote Originally Posted by Violet View Post
    Hi all im after a drawing for a 1997 astra heater as I to have no hot air and am unsure if there is a seal missing or a linkage not conected in the heater box am hoping a drawing might be some help but just to put you all in the picture this is the problom ive got.
    changed the matrix due to it leaking
    blowers work but does not transfer the heat to the vents
    the small flap at the rear bottom of the the heater box hot/cold works fine (cheacked with the matrix out)
    there is a large flap at the front above the matrix but this is not conected to anything but it also does not make a diffrence if its open or shut to the heat.
    if i take the bottom of the heater box off exposing the matrix it is red hot at the front but blowing cold at the rear
    I belive what should hapen is when i open the hot flap on the heater the blower then blows through the matrix but i do not know were it goes from there what i have done to get a little bit of heat at the vents is left the rear of the matrix cover loose so there is cold air escaping and this inturn alows some of the hot air to reach the vents if i tighten them up it all goes (very strange)
    this is a non aircon diesil what has been bleed through with no probs and the matrix gets red hot without any probs.
    Thanks For any info or drawings you can provide me with
    Bri
    Jul 2002
    Leamington Spa
    I don't think diagrams exist.
    I'm trying to find the lever on mine today (an air con model). There are two present (a yellow one at the top left (visible in photo)) and on the right hand side in the middle of the box.
    The one on the top left operates one side of the heater 'splitter' control (the right hand knob), and the one on the right side controls heat - all these do are open flaps inside the box. The heat control simply shuts the heater matrix off from the blower so no heat circulates. It's all mechanical, there's no electronics involved whatsoever.
    The outside air/inside air recirculation (the button below the heater controls) is vacuum operated, meaning it gets air pressure from the inlet manifold, and when the system is open (the button pressed), the vacuum sucks through the rubber pipes and is connected to a lever which closes the two flaps on the top of the heater box (these are visible if you take the pollen filter off the blower unit in the engine bay next to the wiper motor).
    There's another one somewhere, but can't seem to find it - this operates the other half of the heater 'splitter' controls (windscreen/footwell/middle vents, etc).
    MIGWeb Moderator
    Midlands
    Nowt
    Closed, please check thread dates before replying.
Closed Thread
