Alternator vs Dynamo
Results 1 to 8 of 8
Thread: Alternator vs Dynamo
    stt
    stt is offline
    Mar 2003
    Taunton
    Audi RS6
    I'm working on an old Landrover that has a dynamo fitted,
    what are the main advantages of switching to an alternator?
    Why did they change?
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Alternator vs Dynamo
    The major advantage of an alternator over a dynamo is that it is a three phase unit as compared to a single phase unit. In simple terms, alternator will give a much higher charge rate at slow speeds (idle) since on one rotation of the pulley will cut through 3 magnetic flux fields instead of just one.
    also the voltage regulator on a dc gen is far more complicated then it is on a alt, which makes the alternator cheaper, and more efficient, and for a given output, the alternator will alway be smaller than the dynamo thanks to the rotor contruction, so thats why they swapped
    SHoNkyOpELs.de
    stt
    stt is offline
    Mar 2003
    Taunton
    Audi RS6
    Thread Starter
    Thanks Lee
    so on an old workhorse of a landy theres no real benefit in going to the expense of fitting an alternator, if it aint broke dont fix it!
  5. Remove Advertisements
    MSG
    MSG is offline
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Quote Originally Posted by stt View Post
    Thanks Lee
    From what i can remember dynamos used to use a cut Out box which had 3 relays, one establishes an electrical path (switch on contacts) as soon as the Dynmo starts producing a above 12.5Volts and hence couple charging current into the battery and other electrical load, (sorry earlier on I wrote when the ignition was turned on that was incorrect) and then one relay regulates the output current by brifely pulling in when the current exceeded the dynmos rated power, and the 3rd relay pulled in when the voltage reached specified level i.e. approx 14volts, they needed delicate setting and the contacts were spring biased so you could adjust the magnetic pull required for them to trip in on the current and voltage relays.
    alternators are controlled electronically, they generate ac voltage, hence why they call them that but the ac output is converted to Dc using a reactifier and a regulator controls the max voltage, but the current is kind of self limiting by its internal windings resitance and windings are chosen so as to tolerate maximum curent flow (power)
    Dynmos are sluggish when comapred to alternators as explained by lee303. But it does the job as older cars required less electrical power as in them days (1960s)there weren't any heated windows, air conditioners, and many didn't even have a fan blower for internal ventilation!! nor the radiator cooling fan.
    Last edited by MSG; 07-11-2008 at 09:54. Reason: There was a slightly misconcepted statement now corrected
    I am too old for my Calibra and my Calibra is too old for me! we are both stuck!
  7. #5
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Above posters have covered it pretty well - dynamos will produce current at a rate roughly proportional to the RPM, alternators approach maximum output much earlier.
    Alternators are also much more efficient - take less engine power for comparable output.
    Biggest thing you'll have to consider is the electrical draw on the system - standard you should be fine but if you've additional lights, etc, you'll be in trouble very quickly as 'most' dynamos are rated at 25-30 A maximum.
    If appeararances are important, there's at least one firm making specially constructed alternators that have the same look and shape as a dynamo - if you're interested, I'll see if I can narrow it down.
  8. #6
    stt
    stt is offline
    Mar 2003
    Taunton
    Audi RS6
    Thread Starter
    gordo,that would be good if you could narrow it down, as the problem i am going to have is that my power steering pump is built onto the back of the dynamo, so if i change the dynamo for an alternator then i need to rethink the power steering pump!
  9. #7
    Sep 2008
    Hmm, that is a bugger!
    You could try giving these guys a call - have your dynamo converted, perhaps?
    http://www.racemettleltd.co.uk/dyn.html
    Fudge - just noticed this bit "How much do they cost? Prices start from 395.00 including VAT for the C40/L "
    was reading a mag' that had the alt -> gen lookalike, if I find it (!) I'll get back to you.
    I presume you can't/don't want to gut the dynamo internals and use a separate alternator - room and drive problems?
  10. #8
    Apr 2002
    cheltenham
    Mk3 astra sport
    Power steering on old landy? that cant be standard????
