30-10-2008, 18:10
#1 | | MIGWeb User
Join Date: Oct 2008 Location: barnsley Drives: corsa b c20xe
| lambra sensor wiring??? **this is urgent** rite to keep it as simple as possible.
origionally i had a corsa 1.2 16v sxi on a 1999 ecotec and i took that out and put a c20xe engine in out of a 1992 calibra 16v.
basically my problem is, the lambra sensor from the manifold has a male end 3pin adapter, but i cant find what it plugs into, at the minute it is been run without it been connected which is making it over fuel and is down on power.
my question is the 3 wires leading from the sensor (2 black 1 white, or 2 white 1 black, i cant remember) what do they wire into on the loom so it gets rid of the engine management light and stops it over fueling, can this be done, or is there any way of setting the engine up to run without the sensor???
any help will be very much appriciated, cheers steve |
30-10-2008, 18:15
#2 | | MIGWeb User
Join Date: Aug 2007 Location: Kings Lynn (Norfolk) Drives: Corsa c20let
| Re: lambra sensor wiring??? **this is urgent** The othe end of the plug is quite close to were you pulled the loom though the bulk head. |
30-10-2008, 18:16
#3 | | MIGClub Member
Join Date: Nov 2005 Location: Durham Drives: 1.4 Corsa (Honest)
| Re: lambra sensor wiring??? **this is urgent** It goes just where the loom enters the car on the drivers side.
__________________ Man who goes to bed with itchy bum wakes up with smelly finger. |
31-10-2008, 19:42
#4 | | MIGWeb User
| Re: lambra sensor wiring??? **this is urgent** yea i have spotted that multiplug, although they are different connections can i just cut off the connectors and wire them like for like and is there any implacations to this as 2 of the wires are the same colour. dont want to sound thick just precorcious, info so far is great and im very greatful |
31-10-2008, 20:29
#5 | | MIGWeb User
| Re: lambra sensor wiring??? **this is urgent** not all looms have the plug for the lambda, mine hasnt, but it does have another plug in the same place for something else (engine management diag plug i think) just make sure that its the right plug before you cut it up and join it. |
01-11-2008, 01:40
#6 | | MIGWeb User
| Re: lambra sensor wiring??? **this is urgent** is there a distinctive way of been able to tell ( colour of wires, typre of plug or what car the engine came from etc..) cheers steve |
01-11-2008, 14:23
#7 | | MIGWeb User
| Re: lambra sensor wiring??? **this is urgent** as long as theres 2 white and one black. the 2 white are the heater wires and black is the signal wire. cant remember what the loom colours are. look in the haynes book |
01-11-2008, 17:19
#8 | | MIGWeb User
Join Date: Dec 2004 Location: plymouth Drives: Astra GSI LET SCRAPD
| Re: lambra sensor wiring??? **this is urgent** there will be 2 plugs coming out of the loom in similar positions near the bulkhead rubber bung of the loom. on will be in the form of a diagnostics plug (10pin connector) and there should be a 3 pin plug (for the lambda) the purple wire on the loom goes to the black wire on lambda (signal) and the 2 white wires are the heater for the lambda.
you may have a early astra gte loom (20xE) which had no lambda if so you can brigde one terminal on the ecu to earth which turns the ecu into a non lambda type (cant remember which pin)
but check the loom thoroughly for the lambda connector it will be there (unless its the 20xe loom) the connector could have been chopped off accidentally leaving the 3 wires there somewhere.. |
01-11-2008, 22:04
#9 | | MIGWeb User
| Re: lambra sensor wiring??? **this is urgent** thanks for the superb info, ive now sorted it, i found the plug, i had accidentally pulled it through the bulkhead along with the ecu loom connector to the brain.
the eml is now off and running great, just a little problem now, IVE BLOWN THE HEAD GASKET,LOL
changing it 2mora will post back when finished, i cant wait, changed a heater matrix 2day then found the head gasket is gone, my luck really,lol |
Members: 43,224
Threads: 310,664
Top Poster: LEE69 (43,151) | | Welcome to our newest member, LaurenEnzo | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
