Lets start i have digi dash in my corsa b running an c20xe,
the oil warnig light on the digi dash ( not the oil can symbol that flashes) but the four blocks
are all ways showing full....
Is this for the oil level or the oil pressure ???? :doh:
As above - you need to have fitted a 2 wire pressure sender (not pressure switch).
One wire is for the red box which is your low oil pressure warning light and the other wire is an analogue output for the actual pressure which controls the bars on the oil part of the dash.
the pressure switch for the warning light plugs in as normal but there is another terminal for the pressure gauge which needs wiring to the back of the dials
