06-10-2008, 14:04
#1 | | MIGWeb User
Join Date: Apr 2007 Location: Stafford Drives: Corsa Turbo
| Corsa LET Dash light wiring Right few of the dash warning lights dont work so will be going about wiring these up.
Ideally just need to know the colours of the wires and where too look for them.
Wanting to wire up the engine management light
The wire needed to flash the ecu codes up as will be wiring this into a switch
full beam warning light
and oil pressure light.
Cheers |
07-10-2008, 10:41
#2 | | MIGWeb User
| Re: Corsa LET Dash light wiring anyone? |
08-10-2008, 13:00
#3 | | MIGWeb User
| Re: Corsa LET Dash light wiring up. any idea for the engine management light at least??? and where abouts it would/should be?? |
09-10-2008, 20:46
#4 | | MIGWeb User
Join Date: Jan 2008 Location: Port Talbot,S.Wales Drives: Xe Corsa
| Re: Corsa LET Dash light wiring on my xe i connected a blue and a yellow wire to get my management light up..wish i didnt now as it stays on..is there anyway to get it to work properly? i.e come on wen ignition is on and then switch off wen running? |
10-10-2008, 16:22
#5 | | MIGWeb User
| Re: Corsa LET Dash light wiring is this the same on the let aswell?? where is this wire most likely going to be located on both parts of the loom LET side and Corsa side. |
10-10-2008, 16:38
#6 | | MIGWeb User
| Re: Corsa LET Dash light wiring my wires were down in the driverside footwell where my new c20xe ecu was...im not sure if its the same on the let..but thats wat i did mate |
12-10-2008, 17:12
#7 | | MIGWeb User
| Re: Corsa LET Dash light wiring anyone else have any ideas for the other things i need to wire up?? cheers |
17-10-2008, 11:28
#8 | | MIGWeb User
| Re: Corsa LET Dash light wiring anyone else got any info for the ecu light on corsa b let?? on the plug for the clock (rev/speedo) i cant see a blue/yellow wire, i can see a blue/brow wire which looks as if it goes to the ECU light bulb on back of the clocks?? |
Members: 42,517
Threads: 308,006
Top Poster: LEE69 (42,899) | | Welcome to our newest member, rye#1 | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
