Old 05-10-2008, 21:05   #1
tommychimp's Avatar
Drives: Astra Mk3/Mk4 SRi1.8
Astra Mk4 X18XE1 temp guage
Got a wierd one here...
My temp guage sits on rock bottom whilst driving around, whether im giving it some stick or just driving normally. However, if I stop at lights or am in traffic then the guage climbs upto 90 and sits there quite happily but as soon as I move off then the guage starts to drop down to zero.
The fan does kick in and the heaters do get red hot.
Whats going on? Loose connection? Shonky sensor? Thermostat?
1.8 Mk4 Astra SRi
1.4 Mk3 Astra Rattletrap! Soon to be XE Rattletrap!
Too close for missiles; switching to guns
tommychimp is offline   Reply With Quote
Old 05-10-2008, 21:06   #2
Jack's Avatar
Drives: Cavalier 1.7 TD
Re: Astra Mk4 X18XE1 temp guage
Does the rad get completely hot? To the top?
Sounds like a dodgy sender or guage.
Cavalier: Going strong, 153'300 miles and 169ftlbs.
Corsa: XE on the way. Ba-dum tsssh.
Jack is offline   Reply With Quote
Old 05-10-2008, 21:09   #3
tommychimp's Avatar
I haven't checked tbh, what are you getting at mate?
Old 05-10-2008, 21:48   #4
Jack's Avatar
Just wondering, that's all. Unplug the sensor and connect the two pins together. Your guage should shoot round to maximum hotness. If it doesn't, it's not the sender.
Old 05-10-2008, 21:50   #5
Paul's Avatar
One isn't working
Google has the answer
Paul is online now   Reply With Quote
Old 06-10-2008, 17:59   #6
tommychimp's Avatar
Right bridged the connector the needle stayed put, but the fan kicked in.
However I left the engine ticking over and then the needle climbed up.
The rad does get hot all the way up too Jack!
Old 06-10-2008, 18:26   #7
Jack's Avatar
From which sensor?
I thought the temperature sensor for the fan was on the radiator itself? I don't know if that's the same one that drives the guage though.
Old 06-10-2008, 19:43   #8
tommychimp's Avatar
From which sensor?
Well the fan cut in when i unplugged the CTS (in the thermostat housing) and then turned off when i plugged it back in so im assuming the fan is controlled by that sensor. Im thinking the sensor controls the temp signal to the ECU, controlls the fan, and the guage. I'm no further forward now than when i started.
I can't seem to find anywhere on the engine a separate sensor for the temp guage.
Old 06-10-2008, 19:46   #9
Jack's Avatar
Ah, in that case, maybe the guage is driven by the sensor in the radiator.
I can't bloody remember.
Old 06-10-2008, 19:49   #10
tommychimp's Avatar
Nope nor me. I'll have a poke around at the weekend when I've got some daylight.
Old 06-10-2008, 19:58   #11
Jack's Avatar
Bring it round and we'll have a mince with the Corsa too.
Old 06-10-2008, 20:22   #12
tommychimp's Avatar
Sunday guv?
Old 06-10-2008, 20:34   #13
Jack's Avatar
Winner.
I'll speak very nicely to The Management, we might be able to wang you some sunday dinner.
Old 06-10-2008, 20:35   #14
tommychimp's Avatar
Winner.
Oooh ace many thanks!
Old 07-10-2008, 20:14   #15
Drives: Mk3 astra sport
I believe on the Mk4, they have replaced the separate engine management, temperature gauge and fan switch sensors with one sensor which feeds the ECU and then the ECU then drives the temp gauge and feeds the fan ECU.
james sport is offline   Reply With Quote
Old 07-10-2008, 20:32   #16
tommychimp's Avatar
I that would make sense then... I'll pop in and get a new sensor tomorrow and give it a try, not too expensive are they
Old 07-10-2008, 20:33   #17
Drives: Nova 1.6 16v / VXR
As above - there is also some logic that lives in the dial unit IIRC
"Before you judge a man, walk a mile in his shoes.
That way, if you decide you don't like him, you're a mile away from him with his shoes".
Nova SRi 1.6 16v TBs / DTA E48 1/4@14.8s | Astra VXR
phazer is offline   Reply With Quote
Members: 42,347
Threads: 307,091
Top Poster: LEE69 (42,841)
Welcome to our newest member, pippen33pl
