Old 05-10-2008, 20:34   #1
Drives: 1600 Corsa, Nova WIP
RE-programmable ecus
Im currently reading "four stroke performance tuning" by a.graham bell. Its a good book (if anyone cares?).
Anyway, in the book it mentions re-programming ecus already available that can easily be modified. I really like the idea of this but the subject is very lightly touched upon in the book. I have a c/x16xe that i want to fit into a nova and i believe re-programming an ecu would be a cheaper option than buying aftermarket management. Can anyone shed any light with management in c/x16xe's? I know the ecu pretty much cant be re-programmed.
The reason i say c/x16xe is that it is an x16xe wired up as a c16 running c16 management
The book mentions a delco '808' and other gm ecus but non of which make sense to me in there availability of which vehicles they originate from?
Any help with either use of these ecus or tips on aftermarket management would be appreciated
Andrew
Is not going to give out his password anymore
Andrew1988 is offline   Reply With Quote
Old 07-10-2008, 21:00   #2
Drives: tigra let
Re: RE-programmable ecus
try searching for megasquirt on the bay
anniman1 is offline   Reply With Quote
Members: 42,516
Threads: 308,004
Top Poster: LEE69 (42,899)
Welcome to our newest member, scottyanzoey
