Old 05-10-2008, 18:05   #1
Mark_F's Avatar
Drives: Snae a vaux.
Joining Oil cooler lines
Is it safe to do so with jubilees? What sort of pressures can they handle?
Sandwiches and laminated printouts!? You widnae get this at AVA...
Mark_F is offline   Reply With Quote
Old 05-10-2008, 18:32   #2
adidasandy's Avatar
Drives: 1.4 Corsa (Honest)
Re: Joining Oil cooler lines
Would not recommend this at all, don't know on pressures but a lad I knew did this and ended up blowing off a pipe and ****ing his engine big style. Pertek made mine once I gave them the measurments.
adidasandy is offline   Reply With Quote
Old 05-10-2008, 18:35   #3
Mark_F's Avatar
What sort of costs mate? I had ruled it out before but a place I used to work for used them on oil lines and they were rated alot higher than a car oil pump. I questioned it but the fitter said they were always fine, never got a chance to discuss it in detail though.
Old 05-10-2008, 19:43   #4
adidasandy's Avatar
Cost me £50 but it all depends on how much you value your engine, people use jubilee clips often but after seeing what happened to my mates I would never do it. He may have not tightened it up enough and if done correctly it may have been ok.
Up to you bud.
Old 05-10-2008, 19:52   #5
ive joined my oil cooler hoses in 4 places on my LET , made the joiners myself , and jube,d them , not had any problems , with leaks or bursts .
LETSTICK is offline   Reply With Quote
Old 05-10-2008, 19:55   #6
the joiner needs to have a fat shoulder for the jube to butt up to , like a boost pipe has a lip to stop the hose blowing off , never use a straight bit of metal pipe !!!!!! .
Old 05-10-2008, 20:10   #7
Mark_F's Avatar
Up to you bud.
Sounds ideal really as they can make them to size and they are braided lines yar?
Old 05-10-2008, 20:15   #8
Regional Co-ordinator
Lugy's Avatar
Drives: Saab 9000 2.3T
I'd go and visit the Pirtek man too.
They usually have offcuts from bigger jobs which are normally decent sized and can be had for "donations", get some couplings and you're off. Oh and they will have braided hoses.
MIG Performance Saabs
Lugy is online now   Reply With Quote
Old 05-10-2008, 20:17   #9
Mark_F's Avatar
One literally round the corner, will sort it tomorrow.
Old 07-10-2008, 23:45   #10
Drives: Astra GSI LET SCRAPD
yea best to get a braided line made up with new fittings. mocal supply some normal rubber hose and jubilee clips in their oil cooler kits so must be fine. would still recommend new braided pipes tho..
Tomk is offline   Reply With Quote
Members: 42,516
Threads: 308,003
Top Poster: LEE69 (42,899)
Welcome to our newest member, scottyanzoey
