05-10-2008, 15:55
#1 | | MIGWeb User
| Rev counter help please Had another go with my external rev counter... and no didnt suceed. Going to give it one last go and then give up. So annoying as i bet its something really silly im doing. Anyway here are some pictures to ask you which wire does it connect to the ECU. Power is working just no response with the ecu.
Wires everywhere
Is the wire i connect in this block, the square one??
I have wired to the Blue wire 2nd bottom from the left, but this did not work. As you can see there are also green wires that i have read people have wired too. There was four in this set and also found that there was another green wire but covered over in a thick black "overcoat" Is it in this set of wires? if so which one?  |
05-10-2008, 18:54
#2 | | MIGClub Member
| Re: Rev counter help please Looks a right mess.
Please give us/me more info
What car?
What engine?
__________________ Google has the answer |
05-10-2008, 19:44
#3 | | MIGClub Member
Join Date: Sep 2001 Location: Northants Drives: Vectra SRI
| Re: Rev counter help please If its a vauxhall then its normally wired to a plain green wire coming from the main engine ECU |
05-10-2008, 19:45
#4 | | MIGClub Member
Join Date: Sep 2004 Location: East Ayrshire Drives: Snae a vaux.
| Re: Rev counter help please Woah.. Rev counter signal is green that runs to the clocks' loom.
__________________ Sandwiches and laminated printouts!? You widnae get this at AVA... |
05-10-2008, 19:49
#5 | | MIGClub Member
| Re: Rev counter help please Why not just swap your clocks for one with a rev counter? |
05-10-2008, 23:07
#6 | | MIGClub Member
Join Date: Apr 2004 Location: Herts Drives: Nova XE & ST170
| Re: Rev counter help please Looks to me like a 5dr CorsaB. 1.2/1.4?
As said, green from the ECU, there maybe one taped to the loom behind the clocks, failing that I would have thought that you could take a feed from the green at the coil? |
06-10-2008, 08:30
#7 | | MIGWeb User
| Re: Rev counter help please Yeah its a 1.4i corsa b 5dr. Where abouts in the engine is the coil? i Dont have a taped wire behind the clocks that is green. I thought it was a green wire going into one of those plugs? so i take it its not? Which one is the "clocks loom". Thanks for your helps. Quote: |
| Didnt want to change milege and things... Just as easy to get an external one. |
06-10-2008, 10:12
#8 | | MIGClub Member
| Re: Rev counter help please So you have taken your old clocks out, and looked at the plug in the back and there is not a green wire? |
06-10-2008, 19:05
#9 | | MIGWeb User
| Re: Rev counter help please Yeah not that i could see. |
07-10-2008, 12:26
#10 | | MIGClub Member
| Re: Rev counter help please Take another look mate, we are talking about the multi plug that plugs into the clocks.
Pull this out and look, or post a pic of it here |
08-10-2008, 12:20
#11 | | MIGWeb User
| Re: Rev counter help please ok i managed to find that green wire. joint the cable to that and ran cable to the external revcounter and clipped in.... still nothing. Do i not need to touch the ecu at all, as in link another wire to a cable in the ecu? |
08-10-2008, 12:37
#12 | | MIGWeb User
| Re: Rev counter help please IT WORKS!!! Thanks for help . |
15-10-2008, 14:41
#13 | | MIGWeb User
| Re: Rev counter help please how did you get it working mate |
15-10-2008, 17:57
#14 | | MIGWeb User
| Re: Rev counter help please power and ground straight forward. Then the external wire that goes to clocks... I thought to connect to something from ecu but just connected straight to the back of clocks where it plugs in 5the from the left pin. |
15-10-2008, 18:20
#15 | | Administrator
Join Date: Feb 2002 Location: Fareham, Hants. Drives: 1.3L GTE 16V SXi Est
| Re: Rev counter help please For future info, rev counters take the signal from the negative terminal of the (single) coil. |
Members: 42,516
Threads: 308,003
Top Poster: LEE69 (42,899) | | Welcome to our newest member, scottyanzoey | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
