06-10-2008, 18:01
#26 | | MIGClub Member
Join Date: Nov 2007 Location: southend Drives: astra gsi turbo mk3
| Re: Fitting angel eyes mk3 astra No make im affraid |
06-10-2008, 18:09
#27 | | MIGWeb Moderator
Join Date: Mar 2001 Location: C:/UK/Devon/Torquay Drives: Leon Cupra 20VT
| Re: Fitting angel eyes mk3 astra They are for the 2 rings and also the little strip of them at the bottom, join the reds together and join the blacks together, separately, then join them to the sidelights bulb holder which went into the back of the original headlight.
Piece of piss mate. |
06-10-2008, 18:09
#28 | | MIGWeb Moderator
| Re: Fitting angel eyes mk3 astra duplicate post |
06-10-2008, 18:26
#29 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra Ive had to wire them into my main headlights
As what i thought was my sidelight one (2 wire block) Has no voltage?????
Now my bloody speedo dials have no light what is going on? |
06-10-2008, 18:34
#30 | | MIGWeb User
Join Date: Mar 2008 Location: Maldon, Essex Drives: Astra GSi16V 2.0L 91
| Re: Fitting angel eyes mk3 astra You havent changed the wiring loom in the car have you or someone else before? |
06-10-2008, 18:38
#31 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra Ive re fitted all my gauges etc could fitting the lights and now my clocks not working be related?? |
06-10-2008, 18:49
#32 | | MIGWeb User
| Re: Fitting angel eyes mk3 astra I wouldnt have thought so, unless youve wired them wrong and some form of blocking diode is cutting out the circut to prevent a fire! Try unplugging them and see if the clocks work again??? |
06-10-2008, 18:51
#33 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra Cool wlll do that.
You no your side light connector is it a little block 2wires looks exactly like the indicator connector.
Mines has no power to it thats very weird |
06-10-2008, 18:52
#34 | | MIGClub Member
Join Date: Sep 2004 Location: Bristol :) Drives: astra cdx ecodog
| Re: Fitting angel eyes mk3 astra Quote:
Originally Posted by buzball I dont think there a known make to be honest mate il have a check tommorow though |
look like the sonar ones
__________________ Xbox Live! = DEATHS UNCLE |
06-10-2008, 18:55
#35 | | MIGWeb Moderator
Originally Posted by buzball Ive re fitted all my gauges etc could fitting the lights and now my clocks not working be related?? | Not hit the dimmer switch by accident have you? |
06-10-2008, 18:57
#36 | | MIGClub Member
Originally Posted by buzball Now my bloody speedo dials have no light what is going on? | Dash lights are driven from the left hand side-light, IIRC. You might have blown the fuse.
__________________ Cavalier: Going strong, 158'900 miles and 169ftlbs. Corsa: Never get any daylight to work on it! |
06-10-2008, 18:59
#37 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra Thanks jack do you no wot fuse number it is??
Also mate i havent got the little block connected looks exactly the same as the indicator connector
Is this the side light connector as i have no power to that.
Maybe a fuse will sort all of this |
06-10-2008, 19:04
#38 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra I don't know chap. Come on man, do some homework! The little pictures on the inside of the fusebox cover practically give it away.
Stick your circuit tester in and see if it lights up. |
06-10-2008, 19:07
#39 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra Haha forgot about that panel thing
Is that little block thing 2 wires the sidelights?? |
06-10-2008, 19:09
#40 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra If it connects to the sidelight bulb, then yes.  |
06-10-2008, 19:10
#41 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra lol i dont have a sidelight connector on the angel eyes  thats why i was asking  lol |
06-10-2008, 19:13
#42 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra Stick a sidelight bulb from your old lights (the holder and the bulb come out as one thing) onto the wires, then turn the sidelights on. |
06-10-2008, 19:15
#43 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra Dont have any old lights lol
It wont come on though as its reading no power on my volt meter |
06-10-2008, 19:16
#44 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra It will do if you've blown the fuse.  |
06-10-2008, 19:21
#45 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra Yeh true mate i will check tommorow and get back to you
Thanks again pal |
07-10-2008, 11:18
#46 | | MIGClub Member
| Re: Fitting angel eyes mk3 astra Thanks jack and andy for all your help and everyone else
Ive got them wired into the sidelights now
A fuse was blown hahaha |
Members: 42,516
Threads: 308,001
Top Poster: LEE69 (42,899) | | Welcome to our newest member, scottyanzoey | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
