Old 06-10-2008, 18:01   #26
Drives: astra gsi turbo mk3
Re: Fitting angel eyes mk3 astra
No make im affraid
buzball is offline   Reply With Quote
Old 06-10-2008, 18:09   #27
MIGWeb Moderator
LEE69's Avatar
Drives: Leon Cupra 20VT
They are for the 2 rings and also the little strip of them at the bottom, join the reds together and join the blacks together, separately, then join them to the sidelights bulb holder which went into the back of the original headlight.
Piece of piss mate.
MIGclub Calendar 2009 - click to order
LEE69 is offline   Reply With Quote
Old 06-10-2008, 18:09   #28
MIGWeb Moderator
LEE69's Avatar
duplicate post
Old 06-10-2008, 18:26   #29
Ive had to wire them into my main headlights
As what i thought was my sidelight one (2 wire block) Has no voltage?????
Now my bloody speedo dials have no light what is going on?
Old 06-10-2008, 18:34   #30
Drives: Astra GSi16V 2.0L 91
You havent changed the wiring loom in the car have you or someone else before?
blemtime is offline   Reply With Quote
Old 06-10-2008, 18:38   #31
Ive re fitted all my gauges etc could fitting the lights and now my clocks not working be related??
Old 06-10-2008, 18:49   #32
I wouldnt have thought so, unless youve wired them wrong and some form of blocking diode is cutting out the circut to prevent a fire! Try unplugging them and see if the clocks work again???
Old 06-10-2008, 18:51   #33
Cool wlll do that.
You no your side light connector is it a little block 2wires looks exactly like the indicator connector.
Mines has no power to it thats very weird
Old 06-10-2008, 18:52   #34
Jasovanooo's Avatar
Drives: astra cdx ecodog
Originally Posted by buzball View Post
I dont think there a known make to be honest mate il have a check tommorow though
look like the sonar ones
Xbox Live! = DEATHS UNCLE
Jasovanooo is online now   Reply With Quote
Old 06-10-2008, 18:55   #35
MIGWeb Moderator
LEE69's Avatar
Not hit the dimmer switch by accident have you?
Old 06-10-2008, 18:57   #36
Jack's Avatar
Drives: Cavalier 1.7 TD
Dash lights are driven from the left hand side-light, IIRC. You might have blown the fuse.
Cavalier: Going strong, 158'900 miles and 169ftlbs.
Corsa: Never get any daylight to work on it!
Jack is online now   Reply With Quote
Old 06-10-2008, 18:59   #37
Thanks jack do you no wot fuse number it is??
Also mate i havent got the little block connected looks exactly the same as the indicator connector
Is this the side light connector as i have no power to that.
Maybe a fuse will sort all of this
Old 06-10-2008, 19:04   #38
Jack's Avatar
I don't know chap. Come on man, do some homework! The little pictures on the inside of the fusebox cover practically give it away.
Stick your circuit tester in and see if it lights up.
Old 06-10-2008, 19:07   #39
Haha forgot about that panel thing
Is that little block thing 2 wires the sidelights??
Old 06-10-2008, 19:09   #40
Jack's Avatar
If it connects to the sidelight bulb, then yes.
Old 06-10-2008, 19:10   #41
lol i dont have a sidelight connector on the angel eyes thats why i was askinglol
Old 06-10-2008, 19:13   #42
Jack's Avatar
Stick a sidelight bulb from your old lights (the holder and the bulb come out as one thing) onto the wires, then turn the sidelights on.
Old 06-10-2008, 19:15   #43
Dont have any old lights lol
It wont come on though as its reading no power on my volt meter
Old 06-10-2008, 19:16   #44
Jack's Avatar
It will do if you've blown the fuse.
Old 06-10-2008, 19:21   #45
Yeh true mate i will check tommorow and get back to you
Thanks again pal
Old 07-10-2008, 11:18   #46
Thanks jack and andy for all your help and everyone else
Ive got them wired into the sidelights now
A fuse was blown hahaha
Members: 42,516
Threads: 308,004
Top Poster: LEE69 (42,899)
Welcome to our newest member, scottyanzoey
