05-10-2008, 13:35
#1 | | MIGWeb Moderator
Join Date: Apr 2005 Location: coatbridge Drives: carb'd xe nova
| xe keeps chewing new batteries this will be the 3rd brand new battery i will have fitted in the space of 6 months, for some reason after a while my battery seems to drain itself and the only way i can start it every time is with a jump start, after 10 minutes the engine cuts out due to needing a jump start again, the last battery i had checked over to find it was shorted out, any suggestions to what could cause it. alternator, starter motor etc
__________________ Quote:
Originally Posted by Lugy Theres a boy outside riding a unicycle. How bizarre lmao | |
05-10-2008, 13:43
#2 | | MIGClub Member
| Re: xe keeps chewing new batteries Something is draining them thats for sure
__________________ Google has the answer |
05-10-2008, 13:45
#3 | | MIGWeb Moderator
| Re: xe keeps chewing new batteries its running carbs so no ecu and it doesnt have any amps/subs etc, |
05-10-2008, 14:04
#4 | | MIGWeb User
| Re: xe keeps chewing new batteries could be alternator over charging battery which would drain a life of a battery withing months. |
05-10-2008, 14:10
#5 | | MIGWeb Moderator
| Re: xe keeps chewing new batteries thats what i originally thought, it was an alternator fault, not too bothered as my uncle is taking the car this week to be mot'd and have the carbs set up so i will have him look at it then |
05-10-2008, 15:34
#6 | | MIGWeb User
Join Date: Jan 2002 Location: ayrshire scotland Drives: like a saint-9points
| Re: xe keeps chewing new batteries i'd say alternator aswell. put a voltmeter over the battery and see what its reading. should be about 14v with the engine running. did the fault just occur? have you got an earth between the altarnatore adjuster bracket and earth?
rodgerq
__________________ thick red - battery, thin black - igntion switched feed, thick red/blue - fuel pump, brown/blue - ecu light. thin green - rev counter. scrap metal/car lying about? free local uplifts. WANTED, old alloys, exhausts, cats, g/boxes etc. pm me |
05-10-2008, 15:35
#7 | | MIGClub Member
Join Date: Sep 2001 Location: Northants Drives: Vectra SRI
| Re: xe keeps chewing new batteries Could be a dead or leaky diode pack on the alternator causing the battery to drain back through the alternator to ground. |
05-10-2008, 17:37
#8 | | MIGWeb Moderator
| Re: xe keeps chewing new batteries lol problem sorted fan belt had come off, went down to the garage to have a quick look to see if there was any visible problems, noticed the fan belt wasnt on the alternator, will need to tighten up the alternator when i get morwe timwe, infact i will change the belt while im doing it. thankfully it was only that and not 50 quid for a new battery lol |
Members: 42,516
Threads: 308,005
Top Poster: LEE69 (42,899) | | Welcome to our newest member, scottyanzoey | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
