does anyone know how long the glowplugs should stay on after the light goes out.
the light is going out after a few seconds but i know most cars keep the power to the relay for a bit longer. are the 1.5td engines like this.
ive converted my 1.4 petrol to 1.5td & while wiring in the engine loom ive got everything working fine except when i put a voltage tester on the glow plug feed from relay (pink wire) it seems live all the time the ignition is on.
ive only dare leave it on for 30 second as i dont want to overheat the plugs if there is a problem.
maybe these engines stay on for longer or maybe there is some mistake on wiring thats stopping a signal to cut the relay out.
any help would be good. otherwise it will be getting the good old switch on dash for the heater plugs.
