Just bought a corsa sport x14xe which is fitted with aircon, currently the aircon doesnt work but id like to get it going, ive checked all the fuses and they are ok, after doing a search i understand that it may need a re gas and it wont work if the pressure is low, after pressing the little valve under the bonnet there seems to be no pressure. Before i have it regassed tho i would like to check that other bits of it works, when i switch it on the engine doesnt change tone, and the fan doesnt come in so i belive the clutch isnt coming in on the pump. should the clutch still come in with no gas? also if there is a pressure switch for low pressure is it posible to short it out and where is it? just so i can check the clutch on pump and the compressor?![]()
, the thing behind the glovebox whatever it is starts to make a good aircon kinda sound when its switched on. any ideas?
