Omega Sunroof Opens On Its Own Then Closes Again!!!
Hi all iv'e got a mate with a 1998 omega 2.5 elite he's complaining when driving along the sunroof opens on the tilt setting for a few seconds then closes again anyone got any ideas????? his local garage have told him it may be to do with his climate control letting hot air out "sounds like a bit of bulls**t to me" hopefully someone on here will know cheers simon....
Re: Omega Sunroof Opens On Its Own Then Closes Again!!!
Try the sun roof switch for lose connections
Also check it hasn't got wet...
i had that on my cavvi, hav u taken the batt off?
i had to disconnect the diagnostic wire n re set it
to reset it turn it to tilt, push n holt the button in. turn it to closed push n hold the button in then twist it to open twist n hold the button it till its all the way open thn flick it back to closed n hold it again. this should cure it
u shouldnt need to disconnect the diagnostic wire i just had it on there to be abit flash!
hope it helps
To reset it all you do is push and hold the button when the sunroof is closed and the ignition on.
cheers for the info i will try it tomorrow................
