hi all just bought a 1.2 corsa for a bit off A laff/project
to fit bigger brakes do i just need calipers and brackets disc and pads of a cav/astra
is it a straight fit
any info ill gladly take on board![]()
Yes, the callipers/carriers and discs will bolt straight on. The only thing to think about is the wheels as some will clear ATE calipers but others won't. For example Corsa GSI wheels clear but Nova SR 3 spokes don't, due to the clearance to the back of the spokes.
Warren Buffett.
so if i get some calipers/carries off a cavalier or similar then the wheels off a cav would clear the brakes![]()
