05-02-2008, 21:05
#1 | | MIGWeb User
| Astra MK3 Braking Problem Hello all, I have a 1995 mk3 astra td, when the car is running and the brake pedal is pressed a few times in succession the pedal stiffens up, the upon holding steady pressure on the pedal, it seems that the pedal pushes on in. I suspect the master cylinder as there are no leaks. Would a faulty servo cause a problem like this? Any replies gratefully received. |
05-02-2008, 21:18
#2 | | MIGClub Member
Join Date: Dec 2007 Location: Kilmarnock Drives: Vec VXR,Astra GSI
| Has the car got abs , and is there a loss of brake when driving  |
05-02-2008, 21:22
#3 | | MIGWeb User
| Hi Davie, the car has no abs and the brake pedal would require more pressure after the first pump or 2. |
05-02-2008, 21:30
#4 | | MIGClub Member
| Ok then a would suspect that since having no loss of fluid then it would be servo related , worth trying to get a 2nd hand one .Possibly a faulty master cylinder also so maybe worthwhile replacing the two parts |
05-02-2008, 21:32
#5 | | MIGWeb User
| Thanks for your response, Do you know anything about removing the servo? |
05-02-2008, 21:46
#6 | | MIGClub Member
| Never done it myself on a mk3 but basically you would disconnect the brake pedal rod to the servo which would be done from inside the car and then iirc you need to remove the windscreen cowling and then remove the wiper motor and linkage to get to the servo securing bolts. |
06-02-2008, 22:16
#7 | | MIGWeb User
Join Date: Apr 2002 Location: cheltenham Drives: Mk3 astra sport
| As its a Diesel it will have a vacume pump, is that working correctly???
Servos tend to be more reliable than the pumps, so I would recomend looking at the pump first!!! |
06-02-2008, 22:34
#8 | | MIGWeb User
Join Date: Nov 2005 Location: worthing, w/sussex Drives: Astra "G"
| would have said its the m/c as you are getting pressure with a few pumps then it bleeds away. for a mk3 they can be had from £30 upwards from local motor factors or ebay.
__________________ I smile because I don't know what's going on. |
Members: 43,233
Threads: 310,682
Top Poster: LEE69 (43,151) | | Welcome to our newest member, Fadge | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
