Old 05-02-2008, 16:23   #1
Drives: Astra Estate/Van
Car revs drop / Cut out
Awrite,
I`ve got a Vectra, 1.8 16V, (W plate)
When driving and stop the revs die right down then up again, sometimes it cut out, usually junctions, roundabouts that kind of thing. Seen it happen when approaching round about and clutch is in to change a gear, obviously a slow gear change
Any ideas?
I`m planning to get it on a diagnostic machine soon, kinda good if i had a couple of ideas before going in.
StevieC is offline   Reply With Quote
Old 05-02-2008, 16:35   #2
Drives: Mk3 astra sport
ICV sooted up???
james sport is offline   Reply With Quote
Old 05-02-2008, 16:42   #3
Paul's Avatar
Hit the search button and you'll find loads of info on this.
Google has the answer
Paul is offline   Reply With Quote
Old 06-02-2008, 21:12   #4
Drives: mbe calibra 16v
On a W plate its probably the X18XE1 so no idle valve but has a motor the moves the main throttle flap to maintain idle. The usual cause of cutting out at junctions is carbon deposits around the throttle flap, So you will need to give it a good clean out.
Jack-Off is offline   Reply With Quote
Old 07-02-2008, 01:53   #5
Drives: Corsa SXI 2.0
if it has an AFM on this engine check this, they can cause all kinds of problems when faulty or dirty
Hitting Xe rev limiter in corsa is there any better sound
danthexeman is offline   Reply With Quote
Old 07-02-2008, 10:46   #6
Drives: 2.0 Nova, Astra Mk3 est.
Try cleaning the throttle as mentioned above. If not, is the engine management light coming on? Symptoms also sound similar to when the vehicle speed sender fails or is disconnected.
Kieran is offline   Reply With Quote
Members: 43,233
Threads: 310,683
Top Poster: LEE69 (43,151)
