Old 05-02-2008, 10:40   #1
Drives: Astra Coupe 2.2
fixing calibra volt gauge?
I thought that my calibra gauges were faulty and not working, but it seemed to be that the plug was not contacting correctly to supply electricity.
before i worked that out though, i took apart the volt gauge. so i took the needle out, and face off. to expose the coil. there is a coil in the centre of the pin, which has a small length that is straight. i put the needle back on, but it isnt reading correctly.
is there a way i can fix this? its just a case of finding out hwere to place the needle in the correct positon in correspondence to the position of the coil, if anyone knows.
i feel its abit of a waste to throw it away unless its beyond fixing.
cheers
Astra Coupe 2.2 16v
johnsastra16v is offline   Reply With Quote
Old 06-02-2008, 16:31   #2
Paul's Avatar
Sounds scrap.
Would have guessed it was the wiring and not the gauge.
Paul
Google has the answer
Paul is offline   Reply With Quote
Old 06-02-2008, 16:48   #3
Drives: Like its stolen
trial and error taking it off and back on again.
i did the same with a prelude speedo once to fix the light built onto the needle, it never read right ever again, LOL
chip is offline   Reply With Quote
Old 07-02-2008, 18:40   #4
Paul's Avatar
Trial, trial and conclude its broken!
Members: 43,233
Threads: 310,683
Top Poster: LEE69 (43,151)
