Closed Thread
Old 30-11-2007, 16:25   #1
Astra GTE 8V Fuel Problem
I have an astra gte I'm putting back on the road, I have a problem with fuelling as the fuel pump does not get any voltage to it.
I have had the car started on a can of easy start spraying through the AFM. I have checked voltage across the pump with ignition on and whilst trying to start it and nothing - could it be a fuel cut off switch somewhere?
I have a replacement fuel relay coming just in case - also Ive tried a couple of different fuel pumps just in case.
the haynes book of lies doesnt tell me anything.
this is the last bit that needs doing before an MOT so fairly keen to get it going.
Hit me at 40mph and theres an 80% chance I'll die. Hit me at 30mph and theres an 80% chance I'll live. However, if I stopped playing in the middle of the road I probably wouldn't get hit at all.
ComboRich is offline
Old 30-11-2007, 16:30   #2
Regional Co-ordinator
Brett's Avatar
Drives: '88 Astra GTE 16v
Could be a switch in the wire, or just a break. Wont be the pump if its not getting any voltage.
Try the new relay, if that doesnt work check there is a live on the fuel pump wire at the relay. If there is, assume theres a break in the wire for the fuel pump. The wire is a red/blue and runs from the relay, through the round plug to the fusebox, through fuse 19 (IIRC), then along behind the dash, through the big loom harness behind the kick plate in the passenger footwell, and then off to the back of the car along the passenger side. Check along the length for brakages.
If you dont fancy that, just run a new wire in place of the red/blue from the relay to the terminal on the pump, making sure you use an inline fuse
Brett is offline
Old 27-11-2008, 00:04   #3
Re: Astra GTE 8V Fuel Problem
Hi friends, Can anyone help me locate the fuel pump relay on my Astra 1997 (1.4) please
Thanks,
pympilly is offline
Old 29-11-2008, 00:25   #4
Drives: vectra B 8v turbo
try bypasing the fuel pump relay pull the relay out and the 3 thick wires join all them by putting wire in them and see if that works i had to do that on my old one for a few days till got a new relay
i now own the only 1.8 8v turbo vectra B in the uk running 14 psi on megasquirt half the valves double the power
astra mk3 8vt is offline
Old 29-11-2008, 00:27   #5
MIGWeb Moderator
jamied's Avatar
Drives: GTE 3lt V6 TwinTurbo
Old thread...check the dates please...
3ltr V6 Twin Turbo RWD GTE with a touch of NoS http://www.migweb.co.uk/forums/showt...threadid=90683
J.A.D.E Performance ...... Open For Business...Mobile Mech..Repairs..Modding..jadeperformance@hotmail.co.uk
jamied is offline
Closed Thread
Members: 43,233
Threads: 310,683
Top Poster: LEE69 (43,151)
