LinkBack (1) Thread Tools
Old 27-11-2007, 20:01   1 links from elsewhere to this Post. Click to view. #1
vauxhall corsa b eps help
hello there i have just brought a eps (electrical power steering) from net got the full thing its got every thing to trun my corsa b with out the eps to one with only problem i have i i got no idea where the 5 wires that come from the brain box of the eps goes any help plz
jayeshradia is offline   Reply With Quote
Old 27-11-2007, 20:08   #2
MIGWeb Moderator
RobJenko's Avatar
Drives: mk3 astra
moved to a better section for you where you can get the right help.
Wales Regional Co-ordinator
Buy a mig calender! - MIGclub Calendar 2009 - click to order
RobJenko is offline   Reply With Quote
Old 28-11-2007, 14:41   #3
this is the information i have found out so far of some one putting it in a nova is it the same ?
Right,
I have now got the following answers :
Thick Red -> live feed from battery
Thick Brown -> earth
Black/Green -> EPS dash light....... what dash light?
Green -> engine rpm - feed from coil
Light blue/red -> speed sensor (PROBLEM WIRE) ....... i dont get this as welll
Black -> ignition switched positive
Brown/white -> diagnostic feed........ where abouts on the diagnostic feed blook?
Any help would be appreciated
Old 11-01-2008, 01:44   #4
hello to every one that readys this i have got the poer steering to work on my vauxhall corsa 1.4 an its a k reg so if any one wants to put it in there corsa then u can an when yur wiring it up u dont need to wire the eps dash light an the diagnostic wire. but u will have to take your dash out to cut the mealt fram which i did, i cut it with out taking the dash out but when u fit it u need to get a brakit bad so it dont move about thats about it thank u for any one who looks at it :O) jayesh radia
Old 27-11-2008, 17:28   #5
Re: vauxhall corsa b eps help
HIYA i am doin exactly what you are doin and fitting in a corsa b, what did you end up doing with the speed sensor wire? cheers hadley
blueboycorsa is offline   Reply With Quote
Old 27-11-2008, 17:32   #6
donvaux's Avatar
Drives: Corsa GSI c20let WIP
old thread bump alert!
the peed sensor wire goes to the back of the dials its a red/blue wire
If in doubt give it a klout
donvaux is offline   Reply With Quote
Old 27-11-2008, 18:13   #7
hiya sori i forgot 2 mention my cars an 8valve with cable driven clocks, am i pretty much buggered in getting this 2 work cheers
Old 27-11-2008, 18:29   #8
Dom
Dom's Avatar
Drives: Vectra SRI
Are you taking the urine ?
Doms online blog - www.picbits.co.uk/forums but you'll have to register to read it.
Dom is offline   Reply With Quote
LinkBack to this Thread: http://www.migweb.co.uk/forums/other-mechanical-electrical/340128-vauxhall-corsa-b-eps-help.html
Posted By For Type Date
eps corsa b | VIRGILIO Ricerca | Web This thread Refback 07-10-2008 21:29
Members: 43,233
Threads: 310,683
Top Poster: LEE69 (43,151)
