Anyone with a X20XEV Vectra Help please Loose Plug
Results 1 to 2 of 2
Thread: Anyone with a X20XEV Vectra Help please Loose Plug
    Dec 2005
    Ely, Cambs
    Hi I have done the head gasket on my Vectra and I have got it all back together but found a 3 pin plug loose and can't seem to see where to plug it in. It comes from the main loom and goes to a single wire just before the black plastic box where the injector wiring is. I have my Camshaft sensor plugged in and also the other sensor that goes over the top of the engine and down the other side. I just need to know where this wire goes.
    If you have a X20XEV Engine in your vectra could you please have a look for this wire please It would go under the air intake pipe you will see where one wire goes to you Air Flow sensor this wire is near that.
    Here is a picture of the offend wire.
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    Crankshaft sensor on the early loom.
    On the later loom it's on the underside of the injector trunking.
    Check you haven't got the crank sensor plugged into an Empty connector on the trunking.
