help with the wiring on a nova gte
Results 1 to 3 of 3
Thread: help with the wiring on a nova gte
    Dec 2006
    Question help with the wiring on a nova gte
    hi all im building a nova gte back up from the ground but what i dont get is on the loom in the engine bay (not the one from the afm to the ecu) but the one that it attaches to has a red wire which is pretty thick coming out with a circle conecter on the end, Also could you tell me what colour wires go on to the coil pack and what other wire on the starter motor as i have the main live but the other one i have is red and black is this right?
    p.s sorry if it dont make sense its just im urgent to find out what it is thanks
    Dec 2004
    plymouth
    Vectra Challenge Car
    right if i remember correctly, big red from battery goes to the starter motor first then loops off to the alternator, the starter motor will need its feed which should be a black wire with red stripe. then i think its blue/white to the small terminal on the alternator, and blue/green to the oil pressure switch. cant remember about the coil pack
    Dec 2006
    thanks mate thats got me a bit further lol
