corsa redtop
Results 1 to 4 of 4
Thread: corsa redtop
    Oct 2006
    barnsley
    sierra cos & focus R
    corsa redtop
    when i get to around 100mph it seems to struggle to pull anymore. when the engine was in calibra pulled all the way round the clock.
    could this be a fueling issue? i'm using a corsa 1.4 MPI fuel pump,
    as i understand it tho these pumps are high flow, low pressure?? i may be wrong am more knowledgable on fords tbh,
    any help apreciated.
    also i need a gearbox sender for the digi clocks form astra gte if anyone can help me with that cheers
    Jun 2003
    haslington
    zafira gsi
    same thing was up with my mates it turned out to be lambda sensor
    Liverpool
    people up walls
    Pump should be fine.............
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Quote Originally Posted by cavbow View Post
    Can't see any reason why; lambda sensors don't do anything at WOT?
    What exhaust is on it; it could be restricting?
    For the speed sender, check the link to my XE corsa project; on page 1/2 there is a picture of the sensor you need, along with the part number.
