F28 Blue Ring
Results 1 to 3 of 3
Thread: F28 Blue Ring
    May 2006
    Spain
    CorsaC20let, Calibra
    F28 Blue Ring
    Hi from Spain migweb people. I´ve a corsa b with a c20let engine (in procesing), and the last weekend i open the gearbox to fit in it a quaife f28 abt but i have a problem, the blue speedo ring thath goes in the Gm atb has broken and now i dont see this in any shop, the opel dealer tell to me that they dont sell this. This is the problem. I know thath mtech sell one but only valid to the corsa tacho, and i dont know what tacho i go to put. Can people help to me please. I need alot of help because i want the calibra turbo tacho but the corsa tacho is beautifull. If i put the calibra tacho where i can buy this ring? Thank you and please reply to me.
    Jan 2002
    ayrshire scotland
    like a saint-9points
    might need to get it ordered here and sent over mate. if you use the blue ring from the f28 you will need to use the turbo clocks so the speedo is accurate or the alternative is to use the black ring from an f20 and keep the corsa clocks in
    rodgerq
    May 2006
    Spain
    Thank you very much member.
