As per title please!![]()
Originally Posted by wayne451
ttt
off the top of my head i think its the bottom left hand fuse in the fuse box and i think it should be 15Amp
Among the regular blade fuses? I've checked them all dude, both rows and nothing![]()
Fuse 1-20A according to haynes for the horn and radio.
Also runs the interior light
whats the fault youve got is there no switched live at the headunit or no constant live?
if its the switched live try testing between the live and ground whilst moving the ignition key slightly back and forth whith ignition on as it could be a dodgy barrel had this twice before on corsas ive looked at for people
Basically I accidentally touched the power wire for the headunit against an earth point. Since then no headunit power or horn, so I figured the fuse is blown!
I've checked all two rows of blade fuses, so where would fuse 1 be?
Is there a diagram on the back of the fusebox cover/
Yeah, good call. It should be a blade fuse, but I checked them all which is what is baffling me
Awesome, cheers, appreciate that fella![]()
