Current C20xe problem
Results 1 to 8 of 8
Thread: Current C20xe problem
    Jan 2006
    Glasgow
    Was wondering if anyone has had a simular problem and they could point me in the right direction, i have the C20xe fitted to my corsa and sometimes it cuts out for no reason, and sometimes whem left overnight it also dose not start.
    At first when i got the car i had thot that the coil was at fault, so got a new one and still the same, tryed the coil on my friends car and its start no problem so i was able to rule that out, i end up phoneing some mobile out electrian who was about 90 and looked as if he was on his last legs, he took some kind of tester thing (like a pen with a wire on the end of it) and put on end with the crock clips onto the block and then put the probe end onto the one of the terminals of the coil and it fired up first time.
    With him doing that i had thot that all my problems had gone, but no luck, sometimes the car runs fine for days, when it cuts out i just do the same as wot the auto electrian did with the probe and usualy it starts no problem, but today it cut out on some crap backroad and it took maybe 10 mins to start, then ran for 5 mins then cut out again
    Its starting to really piss me off and also if im driving in a bad scheme or something and it cuts out in front of a group of ned (chavs), or at a bad junction or something then its puts you in a bad spot, next time it happens ill take a vid of it and put it up on youtube to see if it could help anyone dianose the problem, its the dizzy type engine and i havnt did the paper clip test yet
    any help would be good
    Mar 2004
    Glasgow
    The coil maybe not earthing properly mate. The one you gave me defo works lol.
    Jan 2006
    Glasgow
    yeah i was thining of something like that too, are u driving a white nova atm
    Jan 2006
    Glasgow
    I remeber the guy i got it from said that it uses some other type of ecu or something, so took a pic, what is this one, is it the one that should be using on the redtop
    Mar 2004
    Glasgow
    Not sure what that ecu's all about and why its got stickers all over it but ive got 2 ecus up here your welcome to try and see if it solves the prob. Cant see it running at all tbh if its the wrong ecu.
    And aye that was me in the white nova lmao
    Jan 2006
    Zagreb, Croatia, EU
    Daewoo Lanos ST
    You need ground mod!
    Mr_G, Crazy scientist
    SMS Commander Car Alarm System
    Woosh Lanos Sport Turbo, c20let inside, F28 ;)
    Jan 2006
    Glasgow
    how do i go about doing that, is it grounding the coil or the ecu or something, im going to take the car to that mod on the ecu as there only 10 mins from me
    Jan 2006
    Zagreb, Croatia, EU
    Daewoo Lanos ST
    Buy some wires like that one for audio amplifiers (8mm2 or so). Then wire ground of accu to every metal part of motor. Like inlet, head, exhaust, coil, alternator, starter, ECU, etc... This way you will solve the problem of pour ground on old wireing....
