Lovely French Megane .
Results 1 to 7 of 7
Thread: Lovely French Megane .
    Dec 2002
    Essex
    Lada Riva
    Right got a Megane 1.4 with a cooling fan fault .
    Tested as follows :
    Short fan switch with ignition on and fan plugged in = nothing .
    Short fan switch with ignition on and put test lamp onto fan plug = lights up .
    Short fan switch and check switch plug with test lamp = lights up .
    Put fan directly onto battery = works fine .
    So there is power going to the switch , there is power getting to the fan from the switch , the fan works when wired directly to battery so WTF
    May 2003
    Cheltenham
    a van
    Not enough power for fan, but enough to light a bulb? Check voltage with a meter
    back on the roads at last!
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Quote Originally Posted by hamster View Post
    .......... across fan terminals with fan plugged in.
    Dec 2002
    Essex
    Lada Riva
    Ok , will check the terminals with meter so what if there is power there to light a bulb but not enough to spin a fan ?
    Voltage drop somewhere obviously and I'm no auto-electrician , worth a check though
    Dec 2002
    Essex
    Lada Riva
    Quote Originally Posted by Dom View Post
    Have actually let it run up to fan cutting in temp and the fan plug still doesn't light up on test lamp but does if you paper clip the fan switch plug
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    With fan plugged in use the bulb tester across one terminal and ground and see if it comes on when it should.
    Then try across the other terminal and ground and see what happens.
    Dec 2002
    Essex
    Lada Riva
    Will try that tomorrow but the fan did come in today once and now nothing again so it's a god damn intermitent fault .
