Anti -Roll Bar help needed on a Mk2 Astra
Results 1 to 5 of 5
Thread: Anti -Roll Bar help needed on a Mk2 Astra
    MIGWeb Moderator
    Midlands
    Nowt
    Just a quick question.
    The links for the anti-roll bar that go from the roll bar to the front suspention wishbone, is there some kind of length they should be once fitted?
    As you will no there is a 13mm bolt that runs through the link and I need to know how tight it should be.
    Thanks,
    Paul
    Jun 2002
    up north
    Girlfriend crazy
    There's a metal tube in the middle. Just tighten the nut until the bushes are compressed by a mm or so. I suppose it's like asking how tight a nut should be. Feel your way. You'll soon know if they're too loose.
    Use the force, Luke.
    MIGWeb Moderator
    Midlands
    Nowt
    Thanks pal.
    Paul
    Sep 2001
    Glasgow Area-ish
    EVO VI & GTE 16
    till the bush and its end caps are compressed to 38mm
    Never get an EGG credit card they do nothing to protect you if your card is subject to Fraud!!!!!!!!!!!!!!!!!!!
    Dec 2000
    Gloucester
    3MW B18iS
    38mm as listed in Haynes manual. It's not too critical though, the tighter you do it the more you squash the bushes.
    No, now f*** ***.
