Pulling (no not THAT)
Results 1 to 11 of 11
Thread: Pulling (no not THAT)
    Dec 2001
    UK
    Mini 1000
    Unhappy Pulling (no not THAT)
    Hello chaps.
    Me Astra's really trying to upset me. Since I've had it, its pulled to the left. I completely rebuilt the suspension struts (properly!) and I've had the tracking adjusted. Still it pulls.
    Happens pretty much all the time - on throttle, off throttle, going fast, going slow.
    It just means that I constantly have to hold it right & I'm sure its scrubbing the tyres. Someone suggested a bent lower arm but I can't see any creases/bends in it.
    There is no play at any wheel, neither are the brakes binding. It's not had a big knock at the front as far as I can tell. It doesn't 'crab' according to a mate that followed me.
    Any idea's???
    Moderator Nobbie's Avatar
    Hemel Hempstead
    with blue lights
    What about CV joints? do they click if you you drive slowly in circles on full lock?
    Alness
    Cavi SRi
    Do you know the history of the car? Could be a bit more major than tracking etc...
    Nov 2000
    Kinross
    172 Clio Ph1
    it can also be caused by uneven road surface, most roads are crowned to allow water to run off and this can affect handling, also binding brakes could cause it to pull left
    charlie dont surf..
    Sep 2001
    rainford
    astra mk4 sport
    mine pulles to left aswell annoyin aint it
    the tracking is fine the tyres r the same well on front ne way the pressures are exact its really annoyin
    May 2002
    Edinburgh
    GTE 16v
    Get your motor to an outfit capable of 4 wheel laser alignment and have it fully checked. The check is capable of castor, camber, track and front to rear wheel/axle alignment. Go somewhere recommended and make sure it's not a spanner chimp doing the work. I khow the tech at Carscan and trust him.
    If corrections are made, you my need to change your tyres before the pulling dissapears.
    Mar 2001
    Torquay
    LC 20VT
    swap the front tyres over left to right and visa versa.
    also check for sticking caliper.
    Sep 2001
    Lancs
    Pug 306 s16
    Mine pulls left too.
    I think its my slider on my left font thats sticking a bit, I squeeks now and again.
    Or maybe it's that mouse in my wing??
    Jan 2002
    Suffolk
    Isuzu Trooper
    I would only trust Elite in Rainham, Essex to sort the tracking etc. on a motor.. they got the 4-wheel thingy.
    Costs a bit but you know it's right.
    Aug 2000
    Putney, London
    MK4 Astra SXI
    What exactly would this suggest? the driveshaft or the CV??
    Are you almost done? I'm touching the proverbial cloth!!!
    Dec 2001
    UK
    Mini 1000
    Thanks for your suggestions, guys. It's not the CV's - I replaced the driveshafts last month. I'll try swopping the wheels around and see if it makes any difference!!
    Awww nuts - hope its not had a major knock.
    I shall report back when I fix it!
    Yes, I WILL SORT IT!!!!!!!!!!
