any one no were i can get replacement locking nut key looks like allan key me whe els are stuck on car and i nee d to change engine mount
I lost a locking wheel nut key a while back, to get the lock nuts off I just found a similar sized socket to the size the nut head and whacked it on with a hammer and undid the nut.
Not possible an all lock nuts tho, maybe wortha try?
i tried braying a socket on .no good these nuts are weird.just enough room for nuts cant even fit a socket in the hole.cheers m8
I have some leagues too. I might have two keys.
I'll check on my lunch from work.
I'll get back to you this aft and if you're still having difficulties I'll pop it in the post first class.
bit expensive but snap on do a tool that is basicly the opposite to an easy out like a socket with spiralling splines inside, *** it on and turn, shud come off if they were fitted by hand and not air gun
cheers lads got it soted today went to a toolmaker got one made to fit cheers thanxs for the help
i got a locking nut from halfords
ford stands for Flogg Or Repair Daily
