traction control/ electric speedo
Results 1 to 16 of 16
Thread: traction control/ electric speedo
    Sep 2006
    where is the traction control sensor on a v6 gearbox? and what colour are the wires. also where is the speedo sensor on the box and how do i wire it up if the car origionally had mechanical one?
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    What Car?
    On Cavalier/Calibra the TC ECU is in the passengers sill panel.
    On Vectra/Omega it's part of the ABS ECU.
    Speed sensors are on all 4 wheels (on rear diff for omega)
    Sep 2006
    iv put a v6 into my astra gsi out of a calibra
    Dec 2001
    Chelmsford, Essex,
    if your GSI had TC, then it will have the same ECU as the V6 in the passenger sill panel.
    You just need to connect up the TC inputs to the engine ECU (on the small connector in the footwell)
    Sep 2006
    do you know about the speedo?
    Sep 2006
    btt
    ZS_
    ZS_ is offline
    Jan 2005
    Belfast
    '03 Astra SXi 2.0DTi
    Speedo is derived from the ABS computer. Same in any car with ABS, or any Vauxhall after 2001 (they use a single ABS hub to get speedo)
    Eat my soot...
    Drives Flame Red 2003 Astra SXi 2.0DTi
    Dec 2001
    Chelmsford, Essex,
    If you have an older GSI that had mechanical clocks, the speed signal won't work from the ABS ECU as you'll have 40 tooth CVs not 29.
    Sep 2006
    ho how can i do it? how did you do yours in your gte mate?
    Dec 2001
    Chelmsford, Essex,
    I have 29 tooth rear hubs and front shafts.
    Dec 2005
    Stoke
    Astra TDS
    think your gonna have to get a mechanical set of clocks or a transducer from an astra GTE with didgi clocks and see if you can wire it up to the elec speed. I sure it can be done as I am looking into that so I can remove my ABS as its buggered
    Dec 2001
    Chelmsford, Essex,
    The F25 doesn't have a Speedo output that's his problem.
    Dec 2005
    Stoke
    Astra TDS
    I thought they had the output but it was just blocked up. Will look into it further. I havent got an F25 on my cav V6 so cant look. Should be some sort of little cover thing on top of the diff housing. Will let you know what I find out
    Dec 2001
    Chelmsford, Essex,
    nope.
    There's no facility on the crownwheel for a speedo drive.
    Sep 2006
    iv got the calibra drive shafts in the front but astra hubs on back. i really need this doing as its on the road now. what bits will i need the v6 clocks and ecu just wiring it up or what ever?
    MIGWeb User jem-autos.com's Avatar
    May 2006
    leicester
    j reg astra gte 24v
    ive got mk2 astra with v6 engine 43 teeth abs rings but on the gear box side of short shaft i had a "sholder" machined on it and fitted a 29 tooth abs ring and made a bracket to hold a abs sensor just for my speedo
