Lowering springs astra coupe
Hey, im needing sum advice as im looking to lower my astra coupe Zlet, ive seen some g-max and spax lowering springs which lower the car by 35mm, would this drop be too much?? as the front is slightly low already. And would this make the suspension stiffer ie when cornering? do i need to change my dampers as well?
35mm drop would be fine, would make it corner like a beaut, new dampers would make it even better. Go for it.
should i get sum standerd dampers or aftermarket ones ie g-max?
Yeh they will be far better than the standard ones, try Bilstein or Eibach they seem to be top quality.
