press on brakes and em light comes on
Some cars (don't know about the Corsa though) have the brake light switch wired to the ECU. What happens in a Corsa if you rev it to about 1200 rpm and whilst holding it at 1200 rpm you press the brake pedal? Do the revs drop to idle speed?
use the hand brake plus its more fun fpmsl
urm not that i know of i will have ago 2moz
when sittin ther and press brake it drops the revs a bit then sorts its self out
ruuuunnnnn awaaaayyyyy..... lmao
West Midlands Regional Coordinator
does it come on strait away or does it happen after holding the pedal down
could be a pressure drop caused by the vac pipe messing up the map sensor
or just something that makes sence unlike that lot up thure/\
it didnt do it today its intermitant
have you got enouth brake fluied in it
yer topped it up a few weeks ago when bleeding the brakes
